Date/Time: Mon, 21 Apr 2025 04:44:15 +0000
Copied "DOM MBO2" not showing MBO Data like Original "DOM MBO 1"
View Count: 375
[2023-02-01 20:50:01]
Thaddeus Fulmer - Posts: 71
I opened a new instance with only trade Doms. the only differnece between Dom that I copied from and Doms in new instance is that I cannot display MBO in the new instance.
I've disconnected and reconnected with no luck.
imageDOM MBO 1.png / V - Attached On 2023-02-01 20:47:05 UTC - Size: 64.27 KB - 92 views
imageDOM MBO2.png / V - Attached On 2023-02-01 20:47:12 UTC - Size: 64.11 KB - 85 views
[2023-02-01 23:15:21]
John - SC Support - Posts: 39362
We are not seeing any MBO data in either of the images you have provided.
How are you starting the second instance, is this using File >> New Instance or is this a completely separate installation of Sierra Chart?
If it is a completely separate installation, then be sure you go through all the MBO setup instructions to ensure that the other installation is setup correctly:
Market By Order Data: Step-by-Step Instructions
