Date/Time: Mon, 21 Apr 2025 04:41:25 +0000
How do I show study name when I have title bar hidden?
View Count: 461
[2023-02-01 20:22:01] |
User525965 - Posts: 153 |
Hi, I have hidden my title bars on my charts. I found that one study name is still showing on one of my charts. I would like to have this for all my charts, however on the rest of them it will only show if I unhide the title bar. I can't figure out what setting I need to change to do this.
[2023-02-01 23:11:13] |
John - SC Support - Posts: 39362 |
We need to make sure we are using the same nomenclature first, as what you are stating is confusing and should not be occurring if it is exactly as you state. The Tile Bar is the bar at the top of the window that is controlled by the Operating System - it is where you grab a window in order to move it around. The Chart Header (or Region Data Line) is the information at the top of the graphics area that can show various information for the chart. The settings in Global Settings >> Customize Chart Header - Standard define what is in that line for a lot of it. But the studies can also write information to the Chart Header. Refer to the following for the settings for a study that affect the chart header: Chart Studies: Subgraphs Tab >> Display Name and Value in Region Data Line Chart Studies: Subgraphs Tab >> Display Study Subgraphs Name and Value - Global Chart Studies: Subgraphs Tab >> Display Study Name Chart Studies: Subgraphs Tab >> Display Input Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
