Date/Time: Mon, 21 Apr 2025 04:44:16 +0000
Download Failed
View Count: 374
[2023-02-01 17:54:17]
Rui S - Posts: 199
Hello SC Support,
With SC Evaluator I can't download data for daily charts with the following CBOT Futures: 2YY, 5YY and 30y. I can download data with 10Y though.
Also, I can download daily data for all these 4 instruments with my Teton account. It is just failing with SC Evaluator Service.
I have tried every "normal" solutions to no avail.
Will you help me, please?
imageCharts after loading atempt.jpg / V - Attached On 2023-02-01 17:52:38 UTC - Size: 116.52 KB - 96 views
imageDownload Failed Message.jpg / V - Attached On 2023-02-01 17:52:48 UTC - Size: 20.26 KB - 101 views
[2023-02-02 14:25:40]
Sierra_Chart Engineering - Posts: 19285
We will check on this and resolve.
Date Time Of Last Edit: 2023-02-02 14:25:44
[2023-02-02 17:34:32]
This is now resolved.
After that:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
[2023-02-02 17:45:00]
Rui S - Posts: 199
It's perfect now.
Thank you.
[2023-02-02 21:24:49]
The reason the particular service makes a difference is because each service has its own Symbol Settings and they were not correctly set to download historical daily data from the right source for these symbols for the trading evaluator services.
