Date/Time: Mon, 21 Apr 2025 04:35:55 +0000
Time discrepancy on VIX chart
View Count: 355
[2023-02-01 17:36:57]
MZTECH - Posts: 29
VIX has gaps daily, which is normal usually around 9:10AM (central). But now when the gap is done, now the time following the gap is incorrect on the chart.
It goes from 9:10AM to 20:15AM
https://www.sierrachart.com/image.php?Image=1675272948454.png
Thanks!
[2023-02-01 22:20:59]
John - SC Support - Posts: 39362
Check the time zone setting for that chart. Refer to:
Chart Settings: Time Zone (List) (Chart >> Chart Settings >> Session Times menu)
And make sure the Session Times are set correctly relative to the time zone:
Chart Settings: Session Times
