Date/Time: Mon, 21 Apr 2025 04:41:24 +0000
Realtime data feed access not happening.
View Count: 314
[2023-02-01 16:47:34]
User972175 - Posts: 2
Cannot access real-time feed/charts following multiple attempts(monthly update). My TransAct account is active and funded. What's going on?
[2023-02-01 22:12:48]
John - SC Support - Posts: 39362
TransAct stopped support for Sierra Chart about 6 months ago, so you can not connect to them anymore. This means you need a different method to verify your non-professional status for the CME Group.
Although we do see that your account is verified through February 28, 2023, so you do not need to do anything right away.
But if you do not already have another account you can use, then refer to the following for a solution:
Easy Solution to CME Funded Trading Account Requirement
