Date/Time: Mon, 15 Dec 2025 09:13:18 +0000
Footprint view
View Count: 538
| [2023-02-01 14:14:19] |
| 20025114 - Posts: 2 |
Hi support, I need help: I cant see correctly the numbers bars without scaling in too much ( I can see clearly only 4-5 box of single number bar) -> This is what I see after reset scale in 5 minutes TF: https://www.sierrachart.com/image.php?Image=1675260335973.png https://www.sierrachart.com/image.php?Image=1675261044891.png Date Time Of Last Edit: 2023-02-01 14:17:53
| [2023-02-01 18:04:49] |
| John - SC Support - Posts: 43443 |
Partially this is due to the nature of the Numbers Bars study and partially it is due to the amount of data that comes from the Crypto data. You will have to play with the scaling no matter what you use, but in order to help you will want to adjust the Volume at Price Multiplier. Refer to the information at the following link: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
