Date/Time: Mon, 21 Apr 2025 04:50:14 +0000
DOM and Scaling Questions
View Count: 793
[2023-02-01 10:11:45] |
TopGunTrader - Posts: 191 |
Hi, I finally got rid of Jigsaw and now trying to get Sierra setup like I loved in Jigsaw, using Teton routing. With DOM's ES and NQ side by side put W as hotkey to auto center them and it works great. It doesn't seem to work with chart based DOM's. Is there some hotkey that centers all chart's with DOMs? I want to scale the charts based on some formula say a separate 5 min chart 20 bar ATR I might want to scale 2x the ATR which with DOM would give me an idea of how far it can move in 10 mins, can this be done? What I want is a fast DOM say 1 sec stair step on close, to recenter it and all other dom charts with a hotkey to line them up, I want to see the market depth graph on chart and lastly in Jigsaw if I had 3 scale in options I could have hotkey that moved them all, Sierra seems to only move closest one and once it hits a higher one up for sell limits stops and can't be yanked up higher, is there a hotkey setting to move ALL stops and all limits? I love in Jigsaw ability to click on price ladder to quickly move a limit to that price, is there a way to do this in Sierra? |
[2023-02-01 10:27:15] |
I just can't seem to get the histogram of depth to use the entire size available. Largest size to me should fill entire amount and rest scaled to the largest which is 150 right now in this screenshot.
[2023-02-01 13:56:23] |
Not sure why but my DOM recenter didn't work yesterday but today is working ignore that part.
[2023-02-01 18:01:44] |
John - SC Support - Posts: 39362 |
With regards to the scaling - this is something we have heard and seen. It is something we need to look into, but it is just not a priority at the moment and there are a lot of other things we are trying to get done.
