Date/Time: Tue, 26 Nov 2024 19:54:42 +0000
AMP CQG
View Count: 1591
[2014-06-07 00:01:21]
User25540 - Posts: 22
I'm a AMP client and want to use sierra chart + cqg.
AMP told me that I must contact SC first and pay for the cqg data feeds directly with SC then SC will let AMP know I have paid them.
After this, the trade desk will build the feed for me.
Could you tell me how to do? Thank you.
[2014-06-07 01:38:23]
This is no longer the case.
Sierra Chart supports the data feed direct from CQG.
You just need to have AMP set you up on the CQG system and then follow the set up instructions here:
http://www.sierrachart.com/index.php?l=doc/CQGTrading.php#SetupInstructions
[2014-06-07 01:49:14]
SO AMP can built a cqg connection for me directly without any notice from SC?
I just need to log in SC with my SC package credentials and connect to cqg if I have an account provided by AMP, is it correct?
[2014-06-07 01:58:08]
Yes. This is all correct.
[2014-06-10 23:12:07]
AMP has built a CQG connection for me but it failed.
AMP is talking to CQG to see what is causing this.
Is there anything Sierra Chart can do?
CQG Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2014-06-11 07:01:35
Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2014-06-11 07:01:35
The network socket is connected. | 2014-06-11 07:01:36
CQG Trading FIX: Sending the Logon message. | 2014-06-11 07:01:36
CQG Trading: Connected to trading server. | 2014-06-11 07:01:36
CQG Trading: Connecting to market data server. | 2014-06-11 07:01:36
Connecting to websocket server. | 2014-06-11 07:01:36
CQG Trading FIX - FCM name: AMP | 2014-06-11 07:01:36
Resolved address api.cqg.com to IP 208.48.16.34 | 2014-06-11 07:01:37
The network socket is connected. | 2014-06-11 07:01:37
Starting SSL connection on the socket. | 2014-06-11 07:01:37
SSL socket is connected. | 2014-06-11 07:01:37
Opening websocket. | 2014-06-11 07:01:37
Sending websocket handshake. | 2014-06-11 07:01:37
Received websocket handshake acknowledgment. | 2014-06-11 07:01:38
TRANSPORT OPEN | 2014-06-11 07:01:38
CQG Trading: Websocket connected. | 2014-06-11 07:01:38
CQG Trading: Sending market data logon message. | 2014-06-11 07:01:38
CQG Trading: Logon unsuccessful. Server message: Logon failed: Trader is not enabled to use SierraChart client application. Please contact your FCM. | 2014-06-11 07:01:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 07:01:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 07:01:38
CQG Trading FIX: Sending a Logout message. | 2014-06-11 07:01:38
SSL shutdown indicates not able to send 'close notify'. | 2014-06-11 07:01:38
The SSL socket has been shut down. | 2014-06-11 07:01:38
The SSL socket object has been freed. SSL state is now disconnected. | 2014-06-11 07:01:38
Socket has been shutdown and closed. | 2014-06-11 07:01:38
CQG Trading: Websocket closed. | 2014-06-11 07:01:38
CQG Trading: Disconnected. | 2014-06-11 07:01:38
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 07:01:38
CQG Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2014-06-11 07:01:38
CQG Trading FIX: Logged out and disconnected. | 2014-06-11 07:01:38
CQG Trading FIX: Disconnected. | 2014-06-11 07:01:38
File >> Disconnect selected. | 2014-06-11 07:01:40
CQG Trading: Disconnected. | 2014-06-11 07:01:40
[2014-06-10 23:23:53]
This message indicates you are not enabled for the Sierra Chart application on the market data connection:
From the documentation for using Sierra Chart with CQG:
Make sure your broker has configured your CQG account with the following CQG Product Enablements:
Enablement = Private Label
FIX Connections = SierraChart (For trading)
Continuum Connect = SierraChartData (Only needed if using the market data feed from CQG)
Date Time Of Last Edit: 2014-06-10 23:24:18
