Date/Time: Mon, 21 Apr 2025 04:35:57 +0000
[User Discussion] - Volumen / sec
View Count: 417
[2023-02-01 08:13:43] |
User491428 - Posts: 87 |
Maybe it's possible to show the volume / second from the "number bars" in curve form? does anyone have experience with it?
[2023-02-01 17:54:04] |
John - SC Support - Posts: 39362 |
We assume you are wanting to see a line of the Volume/Second data from the Numbers Bars Calculated Values. To do this, use the Study Subgraph Reference study and have it reference the subgraph for the Volume/Second in the Numbers Bars Calculated Values. Just make sure the Draw Style for the Study Subgraph Reference is set to Line. Refer to the following: Study Subgraph Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
