Date/Time: Mon, 21 Apr 2025 04:35:50 +0000
Sierra api
View Count: 388
[2023-02-01 05:01:44] |
User989530 - Posts: 34 |
Hello support, I would like to know if its posible in acsil to interact with python for example. Data generated in acsil be accessible by an external program? |
[2023-02-01 17:46:34] |
John - SC Support - Posts: 39362 |
ACSIL uses standard C++, so what you do with it to access Python is up to you. There is a thread on this Support Board regarding Python, if you do a search for "Python" you should find it pretty quick. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
