Date/Time: Mon, 21 Apr 2025 04:35:51 +0000
Automatic monthly payments
View Count: 662
[2023-02-01 02:38:31] |
User273277 - Posts: 64 |
How can I setup automatic direct payment of the monthly fees? I don't want to login to the website every month to move money into a wallet then to you to cover the fees.
Date Time Of Last Edit: 2023-02-01 02:40:22
[2023-02-01 17:35:03] |
John - SC Support - Posts: 39362 |
Go to the Payments page at the following link and scroll to the bottom where there is a section for Automatic Payments through Stripe. Select the button in that section to setup automatic payments and follow the instructions. https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-03 13:39:07] |
Sierra_Chart Engineering - Posts: 19285 |
You can do this through Stripe: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit See the option at the bottom of this page: Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-03 13:39:16
