Date/Time: Thu, 02 Jul 2026 11:13:47 +0000
[User Discussion] - Is There A Way To Detect Whether Caps Lock Is On Or Off?
View Count: 1162
| [2023-01-31 20:59:26] |
| Tony - Posts: 722 |
It's probably a long shot, not sure if it can be done either from Sierra Settings or ACSIL? Thanks in advance. |
| [2023-01-31 22:27:06] |
| ondafringe - Posts: 334 |
You can in ACSIL. Convert the Windows Key Code for Caps Lock in hex (0x14) to decimal (20). if (sc.SetDefaults)
{ //Other Code sc.ReceiveKeyboardKeyEvents = true; return; } int pressedKey = sc.KeyboardKeyEventCode; if (pressedKey == 20) { //Do Something } pressedKey = 0; You might be able to check for the hex value directly, but this was so easy, I never tried to work the hex-check out. Windows Key Codes https://learn.microsoft.com/en-us/windows/win32/inputdev/virtual-key-codes Convert Hex-to-Decimal https://www.rapidtables.com/convert/number/hex-to-decimal.html Date Time Of Last Edit: 2023-01-31 22:42:30
| [2023-02-01 02:09:22] |
| Tony - Posts: 722 |
Hi ondafringe, Thanks so much for your reply! Unfortunately, I am not able to use sc.KeyboardKeyEventCode after version 2439 (sc.CharacterEventCode works fine), most likely it was my Linux+Wine issue, I haven't figured out why ever since. Also, I am hoping to have a sign telling me the current on/off state of Caps Lock. Thanks all the same. cheers, |
