Date/Time: Mon, 21 Apr 2025 04:41:22 +0000
USING A VERTICLE LINE UDID NUMBER THAT I CAN MOVE FOR CODING A ALERT BASE ON TIME
View Count: 317
[2023-01-31 18:05:32] |
User611454 - Posts: 5 |
I Know that I can use a Horizontal line in a alert condition, for example if C>UDID[613].A1 WHICH MEANS THE PRICE IS ABOVE THE LINE 613. CAN I ALSO SOME HOW USE A VERTICLE LINE ALSO TO GIVE ME TIME FACTOR GREATER OR LESS THEN . SO I WOULD LIKE TO USE IT TO SAY IF THE CURRENT TIME (CURRENT PRICE) IS GREATER(OR LESS THEN) THEN THIS VERTICLE LINE. SO THEN I COULD USE IT AS KIND OF MOVABLE ALERT CONDITION TO ALERT OR GET ME INTO A TRADE AT CERTAIN TIME. IF THE VERTICLE LINE UDID NUMBER IS 614 FOR EXAMPLE HOW COULD SAY THE TIME > UDID[614].A1. IN A FORMULA? I HAVE TRIED VARIOUS WAYS BUT NONE WORK. THANKS IN ADVANCE. |
[2023-02-01 15:37:35] |
John - SC Support - Posts: 39362 |
There is not a way to reference the time component of a drawing or of a study for use in an Alert. You could do this using a Custom Study, as you have access to the time component within that environment. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
