Date/Time: Mon, 21 Apr 2025 04:44:16 +0000
TWS API order routing issues(?)
View Count: 715
[2023-01-31 15:43:26] |
User5044343 - Posts: 68 |
I upgraded today to Sierra build 2478 Running TWS 10.21.1l - Java version 1.8.0_202 Getting errors below (orders are not going to TWS) Trading server did not acknowledge new order | Symbol: ES-202303-CME | TradeAccount: xxx| InternalOrderID: 55131 | ServiceOrderID: 52451 | Current Status: Order Sent | 2023-01-31 15:33:26.804 * Interactive Brokers | Requesting Open orders. | 2023-01-31 15:33:46.397 Interactive Brokers | Sent reqAutoOpenOrders request | 2023-01-31 15:33:46.397 Interactive Brokers | Received Open orders end message. | 2023-01-31 15:33:47.269 Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 2 | 2023-01-31 15:33:49.003 Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 2 | 2023-01-31 15:33:49.003 Interactive Brokers | Requesting Open orders. | 2023-01-31 15:33:58.353 Interactive Brokers | Sent reqAutoOpenOrders request | 2023-01-31 15:33:58.353 Interactive Brokers | Received Open orders end message. | 2023-01-31 15:33:58.355 Trading message from IB: Manual Order Cancel Time: The date, time, or time-zone entered is invalid. The correct format is yyyymmdd hh:mm:ss xx/xxxx where yyyymmdd and xx/xxxx are optional. E.g.: 20031126 15:59:00 US/Eastern Note that there is a space between the date and time, and between the time and time-zone. If no date is specified, current date is assumed. If no time-zone is specified, local time-zone is assumed(deprecated). You can also provide yyyymmddd-hh:mm:ss time is in UTC. Note that there is a dash between the date and time in UTC notation. Error Code: 10301. ServiceOrderID: 52452. InternalOrderID: 55132. | 2023-01-31 15:34:17.058 * Order cancellation failed | Manual Order Cancel Time: The date, time, or time-zone entered is invalid. The correct format is yyyymmdd hh:mm:ss xx/xxxx where yyyymmdd and xx/xxxx are optional. E.g.: 20031126 15:59:00 US/Eastern Note that there is a space between the date and time, and between the time and time-zone. If no date is specified, current date is assumed. If no time-zone is specified, local time-zone is assumed(deprecated). You can also provide yyyymmddd-hh:mm:ss time is in UTC. Note that there is a dash between the date and time in UTC notation. Internal Order ID: 55132. Service Order ID: 52452. Symbol: ES-202303-CME. Account: xxxx| 2023-01-31 15:34:17.058 * |
[2023-01-31 17:18:14] |
John - SC Support - Posts: 39362 |
Make sure you are on the most current "Stable" release from Interactive Brokers.
[2023-01-31 18:16:57] |
Was running Latest. Now installed "stable" - 10.19 ( https://www.ibtws.com/en/trading/tws-offline-stable.php) - Orders still not getting passed on. |
[2023-02-01 00:38:29] |
I downgraded Sierra to 2459 and it works.
[2023-02-01 14:12:05] |
Sierra_Chart Engineering - Posts: 19285 |
We will check on the errors in post #1. But for the record, the TWS API is a fully unacceptable system for trading. A completely poor quality unacceptable design. Does not even meet any reasonable standards at all. We are contemplating dropping support for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-01 14:13:22
