Date/Time: Mon, 15 Dec 2025 09:10:57 +0000
Update Interval - Per Chart instead of Global?
View Count: 607
| [2023-01-31 15:41:34] |
| Rickty - Posts: 35 |
Can update interval be set by individual chart instead of globally? I'd like to run a single chart with an increased frequency that will freeze system if applied globally.
| [2023-01-31 17:13:43] |
| John - SC Support - Posts: 43443 |
Refer to the following: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-01-31 18:35:44] |
Thank you. I looked around before asking, but missed that. Much appreciated.
| [2023-01-31 20:12:15] |
Is there any way to lower the refresh update below 10ms? Any way at all?
| [2023-02-01 15:39:49] |
No, there is not. 10ms is the fastest available.
