Date/Time: Sat, 19 Apr 2025 11:57:16 +0000
previous version
View Count: 403
[2023-01-31 15:30:10] |
User256765 - Posts: 1 |
Hello, I downloaded the latest version of Sierra Chart on my Windows PC, however, I used Sierra Chart with Infinity Futures a few years ago, and the chart setting, General setting, etc...were different! We didn't have a black window with few options, but a white window with many more options. Could I download that version of Sierra Chart? thank you |
[2023-01-31 16:55:26] |
Sierra_Chart Engineering - Posts: 19276 |
It is not recommended to use a significantly older version of Sierra Chart. You are referring to the Settings Windows. Here is the documentation for the new Settings Windows and configuring them to appear like you require: Settings Windows Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-31 16:57:30
