Date/Time: Mon, 21 Apr 2025 04:47:15 +0000
Horizontal Line Text Alignment
View Count: 602
[2023-01-31 10:12:45]
User688525 - Posts: 284
Hello Sierra Chart,
When horizontal line text extends over two or more lines, the text no longer right aligns. Are instructions available on how to achieve this, or is this a potential feature request. See the attached.
Thank you
imageSierra Chart - Horizontal Line Text.png / V - Attached On 2023-01-31 10:12:13 UTC - Size: 5.44 KB - 112 views
[2023-01-31 15:55:39]
John - SC Support - Posts: 39362
Set the Horizontal Alignment to Left. We know it seems counter-intuitive, but this is the terminology that is used by Microsoft for the alignment.
[2023-02-01 02:50:07]
Hello John,
When set to "Left", the text is now left aligned, not right aligned which is what I would like to achieve.
imageSierra Chart - Horizontal Line Text Left Aligned.png / V - Attached On 2023-02-01 02:49:59 UTC - Size: 4.17 KB - 97 views
[2023-02-01 17:40:55]
Sorry, I forgot that Horizontal Line has different settings from the Line tool, which is the one I was using to make sure I gave the right information.
The only option is the Right Aligned and it is just the way it is.
[2023-02-02 00:11:45]
John,
Can this be added as a feature request?
[2023-02-02 15:29:46]
Yes, we accept the feature requests, but we can not say when we would get to this particular change.
[2023-02-02 22:51:20]
Is there a feature request board or thread, or what is the process?
[2023-02-02 23:57:40]
You have already done it by asking here.
[2023-02-03 01:10:24]
Thank you John.
