Date/Time: Sat, 19 Apr 2025 12:00:27 +0000
DPL is counted double, half or ten times
View Count: 637
[2023-01-31 09:01:51] |
Chriz - Posts: 2 |
Hi, I am encountering a strange behaviour since yesterday, where my DPL is counted 10x, double or only half depending on the chart book (I use 2 cbs). I trade MES March contracts in both via a IBKR connection. The DOM and chart are set to show ES. I followed the instruction in the How-To correct DPL mistakes, but everything is set correctly (and as it was set up last week) I read through this thread, but since my chartbook is rather complex, I want to avoid setting it all up again (DPL not correct) What I found out so far: - Simulation mode works just fine, counting correctly in both chartbooks. - Until yesterday evening one chartbook still worked while the other counted double, this morning one started to count only half. please see the attached screenshots, its a simple trade short 1 contract MES, 8 pts lower buy back. Yet, its counted as 4 points. I also included a screenshot of my chart trading settings. Date Time Of Last Edit: 2023-01-31 09:07:20
[2023-01-31 15:23:26] |
John - SC Support - Posts: 39362 |
We are not understanding the issue. You state that the trade you made as for a profit of 4 points, which is what your Daily P/L is showing - 4 points profit. Is the issue just that one chartbook is displaying in Points and the other is in Currency or Ticks? Refer to the following: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-31 15:41:18] |
Chriz - Posts: 2 |
Hi, sorry, maybe lets just stick to one chartbook, since they both behave strangely it shouldnt make a difference. So in the mentioned chartbook I did one trade, which I am showing in the screenshot: sold: 1 x 4039.5 bought: 1 x 4031.5 result: +8 DPL What SC shows: +4 DPL In this chartbook the Profit/Loss format is set to Points (no other options, see new Screenshot) If its helps in any way: I did some more trades today and right now I cant seem to find any connection between my trades and my shown points. I am overall positive (which I also verified via the IBKR Acc statement), yet SC shows me a DPL of -23.25 O_o Date Time Of Last Edit: 2023-01-31 15:47:49
[2023-01-31 17:12:59] |
Since it is your Daily P/L that is not showing properly, refer to the following: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
