Date/Time: Mon, 21 Apr 2025 04:38:31 +0000
[Programming Help] - Pers Double not providing the expected outcome.
View Count: 353
[2023-01-31 08:47:00]
User92573 - Posts: 559
Dear Support
I'm obviously missing something simple but as I'm not a programmer this is a little confusing.
Can someone help explain why the increased precision results in a 0?
float& Simple_calc1 = sc.GetPersistentFloat(1);
double& Simple_calc2 = sc.GetPersistentDouble(1);
Simple_calc1 = 10/5; // ignoring use of 10.0f/5.0f
Simple_calc2 = 10/5;
msg.Format("Simple Calculation using float = %f",Simple_calc1);
sc.AddMessageToLog(msg,1);
msg.Format("Simple Calculation using double = %d",Simple_calc2);
Message Log output:
Simple Calculation using float = 2.0
Simple Calculation using double = 0 //?
Many thanks for any help.
[2023-01-31 08:57:45]
User431178 - Posts: 649
When using the format function d means signed integer, you need to use f in both cases.
[2023-02-01 08:56:58]
Thank you, for some reason I'd made a mental note %D was a double hence greater precision, not an integer.
When I did a quick search there it was, Int Base 10. So, output was consistent with C++ as opposed to my mental note.
Many thanks for replying.
