Date/Time: Sat, 19 Apr 2025 11:57:16 +0000
Decimal number
View Count: 422
[2023-01-30 05:35:41] |
User117548 - Posts: 28 |
Hi team, I hope you guys have a good day! I am really enjoying trading with Sierra as it provides a number of useless tools! However, I am struggling with volume decimal numbers. For example, in my attached image, the volume for future gold ( I am using continuous future contract - Volume based rollover) and volume always display in .0, like 20.0/ -10.0. Is there any way to make this 20.0 volume become 20 only? as it is unnecessary to have .0 in gold volume and it distracts me from data. I tried "adjust data" function ( from this article Adjusting Data ) but somehow it did not work. After I press OK (I only change Volume multiplier from 1 to 10), volume displays still as 20.0. When I reopen "Adjust data" window again, I saw that volume multiplier turned back to 1 again. Please kindly help me in this case Thank you |
Attachment Deleted. ![]() |
[2023-01-30 08:59:49] |
User431178 - Posts: 649 |
In the study setting window, set the Value Format to 1, that is it. Chart Studies: Settings and Inputs Tab >> Value Format |
[2023-01-30 09:08:07] |
Hi, Thank you for your reply. I did put it like you said ( actually, i believe the default is 1 already) but it still havent changed my volume number ( see my attached image). |
[2023-01-30 09:44:09] |
No, that is the chart settings window, you need to set it for the appropriate study in the Study Settings Window. Chart Studies: Study Settings Window |
[2023-01-30 11:32:53] |
Really thank you. I got it!!! |
