Date/Time: Sat, 19 Apr 2025 11:57:13 +0000
sub instance auto shutdown
View Count: 425
[2023-01-29 22:31:31]
User654047 - Posts: 15
Anyone know how to setup auto shutdown of sub instances with main?
[2023-01-29 23:20:10]
Sierra_Chart Engineering - Posts: 19276
This is not supported although maybe you could do something like this by using auto hotkey:
https://www.autohotkey.com/
You could invoke File >> Exit.
The title bar of each sub instance is unique because it has the sub instance number and you can use auto hotkey to identify it.
Date Time Of Last Edit: 2023-01-29 23:20:25
