Date/Time: Mon, 21 Apr 2025 04:44:12 +0000
Chart sizing for different screen sizes
View Count: 880
[2023-01-29 21:37:06]
User879924 - Posts: 50
Sometimes I trade off a 27inch monitor and sometimes I trade off a laptop. When I do this I have to to resize the charts so that they fit properly within the smaller screen. I usually display 2 DOM's and a candle stick chart side by side. Is there a quick way to keep the same layout but have the charts resize for the screen size?
Thank you
[2023-01-30 02:33:14]
Sierra_Chart Engineering - Posts: 19285
No, this is not supported. You have to manually resize the charts.
Would be best to have separate installations of Sierra Chart one for each monitor size.
[2023-02-01 11:25:38]
Mercrastius - Posts: 46
Separate installations? Just save two separate chartbooks.
You'll probably want to have everything detached from the main window in both layouts - charts, DOMs, everything. Keep nothing in the main chart window, then just minimize it.
Date Time Of Last Edit: 2023-02-01 11:34:44
