Date/Time: Sat, 19 Apr 2025 12:00:27 +0000
Show Order Fills on a Chartbook Template
View Count: 342
[2023-01-28 06:34:37]
User856926 - Posts: 9
I am able to change the color of the chart order fill markers on a new chart; however, I am unable to change the marker colors on a chart book template I received from someone else. I've confirmed that the Global Settings/Graphics Settings - Global configuration is correct and have even restarted Sierra charts but I am unable to override the defaulted green and burgundy marker colors. Is it possible that there is lock on the settings that prevent changes to the template?
[2023-01-30 15:18:29]
John - SC Support - Posts: 39362
Most likely the chart(s) in that chartbook are setup to Chart Specific graphics settings. In which case, you need to select Chart >> Graphics Settings - Chart and either enable the option at the top for Use Global Graphics Settings Instead of These Settings, or change the colors as you want for the chart.
Note the information at the following link regarding Chart specific graphics settings versus the Global graphics settings:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
