Date/Time: Mon, 15 Dec 2025 09:11:42 +0000
Trade service logs to a file
View Count: 684
| [2023-01-28 03:23:33] |
| User648547 - Posts: 1 |
Hi, At present, trade service log messages can only be analyzed manually by looking at the trade service log window. Is there a way to send this to a file, automatically, similar to alert and message logs. Thanks, Lata |
| [2023-01-30 15:04:43] |
| John - SC Support - Posts: 43443 |
There is not a way to save the Trade Service Log, and the information in it is only kept while Sierra Chart is running (the information is lost when you exit from Sierra Chart). But you can use the Trade Activity Log which stores data permanently and can be saved. Refer to the following: Trade Activity Log: Importing and Exporting Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
