Date/Time: Sat, 19 Apr 2025 11:58:46 +0000
volume by price on number bars study
View Count: 837
[2023-01-27 15:43:19]
User447431 - Posts: 29
Im using the study volume by price, and i want to:
1. put the volume profile on the right side of the number bar candle
2. on the right side of the volume profile i want to put the delta volume
What setting i have to change on vbp study or number bars? thanks
i uploaded my currently screen and other with the vbp and delta on the right side
Date Time Of Last Edit: 2023-01-27 16:05:09
imagevbp.JPG / V - Attached On 2023-01-27 15:35:48 UTC - Size: 107.05 KB - 239 views
imagefootprint.JPG / V - Attached On 2023-01-27 16:04:43 UTC - Size: 22.28 KB - 238 views
[2023-01-27 19:13:51]
John - SC Support - Posts: 39362
To get what is shown in the image you are trying to replicate, you only need the Numbers Bars study. You will not use the Volume by Price study. The following information will get you the basic setup, we are not going to go into every little setting to exactly replicate the image.
In the Numbers Bars study set the following:
- Column 1 Numbers Bars Text: Bid Vol x Ask Vol
- Column 1 Background Coloring Method: None
- Column 2 Numbers Bars Text: Ask Vol Bid Vol Difference (or other Delta value you want to use)
- Column 2 Background Type: Volume Profile
- Column 2 Background Coloring Method: Based on Volume Percentage (or other item of your choosing)
- Single Value Text Alignment: Right
