Date/Time: Sat, 19 Apr 2025 11:58:45 +0000
Main chart is completely unresponsive
View Count: 323
[2023-01-27 14:46:40]
ssangha84 - Posts: 128
Hello, I am not sure what happened but I was using the charts just fine today. But all of a sudden my main chart became completely unresponsive. I have a picture attached, when I click the sierra chart logo, the main screen is the white one, and absolutely nothing happens when I click on it. This is happening with both instances. I tried restarting my computer and its still doing the same thing. I tried pressing alt + tab to get to it, and same thing, no response whatsoever.
imageChartGlitch.jpg / V - Attached On 2023-01-27 14:46:18 UTC - Size: 251.45 KB - 96 views
[2023-01-27 15:31:41]
Sierra_Chart Engineering - Posts: 19276
Restart Sierra Chart, if you have to terminate the process, then do that, and then on the login window disable Open Files on Startup:
Sierra Chart - Software Login Instructions: Disabling Automatically Opening Files on Startup
And then see if Sierra Chart is responsive without any Chartbooks open.
Date Time Of Last Edit: 2023-01-27 15:32:24
[2023-01-27 16:36:01]
Thank you,
I went to Window>Reset windows and that took care of it
