Date/Time: Tue, 26 Nov 2024 18:36:59 +0000
[User Discussion] - Using Spreadsheet Time to Calculate Slope
View Count: 1355
[2014-06-06 07:41:58]
djcurcio - Posts: 236
I want to calculate the slope of price changes in a spreadsheet.
This requires calculating the difference between the two times - for example A4-A3.
But I cant seem to get A4-A3 to work properly - all I get is 0.00 Setting the cell format to time does not help.
I assume I must somehow convert the values in A to seconds and then do the subtraction.
And then convert the subtraction result back to decimal minutes - ie 121.33 minutes - no hours to get the slope in minutes.
Does anyone know how to do this in the spreadsheet?
[2014-06-06 13:33:41]
Sawtooth - Posts: 4120
Here's some info on spreadsheet time formats:
http://www.sawtoothtrade.com/tip-4.html
Since the spreadsheet study array is in descending order, A3 is a greater value than A4.
To get the exact value in seconds between A3 and A4:
=(A3-A4)*86400
Or in minutes:
=(A3-A4)*1440
Or in hours:
=(A3-A4)*24
Date Time Of Last Edit: 2015-08-14 02:02:11
