Date/Time: Sat, 19 Apr 2025 09:46:40 +0000
ES data is messed up
View Count: 316
[2023-01-26 15:42:11] |
fish4trout - Posts: 99 |
Data for ES is not correct? I switched charts in chartbook to MES and NQ and the data is fine. Appears to be something with the session times maybe? https://www.sierrachart.com/image.php?Image=1674695248716.png So I went to Edit>Delete all Data and Download and now everything appears to be fine. Just curious as to what causes something like that to happen? |
[2023-01-26 17:44:27] |
John - SC Support - Posts: 39362 |
Usually it's caused by some kind of connectivity issue when the data was starting to be downloaded and then got stopped in the middle. But you did the right thing, which was to do the "Delete All Data and Download" to get the missing data to fill in. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
