Date/Time: Sat, 19 Apr 2025 11:58:42 +0000
Change DPL from C, P to AUD
View Count: 716
[2023-01-26 15:30:31]
User599487 - Posts: 10
Hi Support
I would like to change the DPL from its current setting of Currency and Points to Australian Dollars AUD.
Please assist.
https://www.sierrachart.com/image.php?Image=1674717247396.png
[2023-01-26 17:18:52]
John - SC Support - Posts: 39362
Refer to the following setting to change the currency:
Global Trade Settings Windows: Common Profit/Loss Currency (Global Settings >> General Trade Settings >> General)
[2023-01-26 23:24:11]
Hi Support
I updated the F.US.MES?## symbol currency to AUDC but the DPL does not change and remains with C and P.
I seen the DPL presented with AUD before so I know it can be done.
Please assist further.
https://www.sierrachart.com/image.php?Image=167477543423.png
[2023-01-27 16:00:29]
Sierra_Chart Engineering - Posts: 19276
How exactly did you do this?:
That is not a valid currency code.
[2023-01-27 19:10:45]
What is the valid code for AUD? AUD?
[2023-01-27 19:51:59]
You should not be changing the currency code of the symbol itself. That needs to be the actual currency that it trades in.
You just need to select the currency for your Profit/Loss in the Common Profit/Loss Currency.
