Date/Time: Sat, 19 Apr 2025 11:58:46 +0000
Trading evaluator updating very slow including priceline(s) not following pricelabel
View Count: 405
[2023-01-26 13:56:30] |
User779524 - Posts: 5 |
Dear Reader, I am using the trading evaluator for practice and it is very slow to the point when price changes fast it records the wrong situation. I went through my targets without a stoploss and recorded a loss. on 26-01-2023 just after 15:30 I think that this should not be possible. Thank for your answer! |
[2023-01-26 15:06:40] |
Sierra_Chart Engineering - Posts: 19276 |
We are not observing any problem with the trading evaluator service. We want to make sure you are getting real-time data. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-26 15:18:59] |
Dear Reader, I followed the action in the email have sended the message log. Regards, Software version: 2457 64-bit | 2023-01-26 17:12:34.872 Primary Thread ID: 7376 | 2023-01-26 17:12:34.872 Usage end date: 2023-03-29 | 2023-01-26 17:12:34.872 Enabled for: Advanced Features 2. | 2023-01-26 17:12:34.872 Enabled for: Sierra Chart Historical Data Service. | 2023-01-26 17:12:34.872 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-01-26 17:12:34.872 Enabled for: Delayed Denali Exchange Data Feed. | 2023-01-26 17:12:34.872 Enabled for exchange2: CME | 2023-01-26 17:12:34.872 Enabled for exchange2: fairx_exchange.data | 2023-01-26 17:12:34.872 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-01-26 17:12:34.872 Current selected Data/Trading service: Trading Evaluator | 2023-01-26 17:12:34.872 Custom symbol settings values: disabled | 2023-01-26 17:12:34.872 Chart Update Interval: 500 | 2023-01-26 17:12:34.872 Intraday Data Storage Time Unit: 0 | 2023-01-26 17:12:34.872 Time Zone: +02:00:00 (EET+02EEST+01,M3.5.0/03:00,M10.5.0/04:00) | 2023-01-26 17:12:34.872 2023-01-26 15:12:34 Local computer time in UTC | 2023-01-26 17:12:34.872 2023-01-26 17:12:34 Local computer time in SC Time Zone | 2023-01-26 17:12:34.872 2023-01-26 11:34:09 Server time in UTC | 2023-01-26 17:12:34.872 Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-01-26 17:12:34.872 Program path: C:\SierraChart\ | 2023-01-26 17:12:34.872 Data Files path: C:\SierraChart\Data\ | 2023-01-26 17:12:34.872 OS Version Number: 10.0 | 2023-01-26 17:12:34.872 Locale Setting: C | 2023-01-26 17:12:34.872 DLLs: Emoji Trading Order Flow Suite.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, Zyp Free by Zyp_64.dll, Zyp OrderFlow by Zdislav_64.dll, Zyp Trade_Your_Plan_64.dll | 2023-01-26 17:12:34.872 Allowed protected custom studies: zyp_app | 2023-01-26 17:12:34.872 Crash reporter started: true | 2023-01-26 17:12:34.872 File >> Disconnect selected. | 2023-01-26 17:13:47.645 Trading Evaluator | Waiting for socket receive thread to end | 2023-01-26 17:13:47.650 DTC Client socket (3) | CloseSocket call. | 2023-01-26 17:13:47.650 DTC Client socket (3) | Max send buffers used during socket life: 3 | 2023-01-26 17:13:47.650 DTC Client socket (3) | Max send buffer size during socket life: 500 | 2023-01-26 17:13:47.650 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-01-26 17:13:47.650 SC Data - All Services | Waiting for socket receive thread to end | 2023-01-26 17:13:47.650 DTC Client socket (1) | CloseSocket call. | 2023-01-26 17:13:47.651 SC Data - All Services | Disconnected from the server. | 2023-01-26 17:13:47.651 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2023-01-26 17:13:47.651 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-01-26 17:13:47.651 DTC Client socket (2) | CloseSocket call. | 2023-01-26 17:13:47.651 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-01-26 17:13:47.651 SC DTC Delayed Exchange Data | Disconnected from the server. | 2023-01-26 17:13:47.651 Trading Evaluator | Disconnected. | 2023-01-26 17:13:47.651 DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-01-26 17:13:47.801 DTC Client socket (3) | Closed. | 2023-01-26 17:13:47.801 Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2023-01-26 17:13:56.485 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2023-01-26 17:13:56.485 DTC Client socket (3) | New receive buffer size: 5242880 | 2023-01-26 17:13:56.485 DTC Client socket (3) | Connecting to IP: 142.215.17.188. | 2023-01-26 17:13:56.486 Trading Evaluator | Network connection to server complete. | 2023-01-26 17:13:56.636 Trading Evaluator | Starting socket receive thread. | 2023-01-26 17:13:56.636 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2023-01-26 17:13:56.636 Trading Evaluator | Setting DTC encoding to Binary VLS | 2023-01-26 17:13:57.111 Trading Evaluator | Sending logon request message. | 2023-01-26 17:13:57.111 Trading Evaluator | Received logon response. | 2023-01-26 17:13:57.815 Trading Evaluator | Server Name: SC DTC Server. Build=44583. | 2023-01-26 17:13:57.815 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2023-01-26 17:13:57.815 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2023-01-26 17:13:57.815 Trading Evaluator | Trading is supported. | 2023-01-26 17:13:57.815 Trading Evaluator | Order cancel and replace is supported. | 2023-01-26 17:13:57.815 Trading Evaluator | OCO Orders supported. | 2023-01-26 17:13:57.815 Trading Evaluator | Bracket Orders supported. | 2023-01-26 17:13:57.815 Trading Evaluator | Connected to server complete. | 2023-01-26 17:13:57.815 Triggering next historical data download in queue. | 2023-01-26 17:13:57.816 Triggering next historical data download in queue. | 2023-01-26 17:13:57.816 Triggering next historical data download in queue. | 2023-01-26 17:13:57.816 Triggering next historical data download in queue. | 2023-01-26 17:13:57.816 Trading Evaluator | Performing query for most recent Order Activity Date-Time. | 2023-01-26 17:13:57.821 No download requests in the queue to start downloads for. | 2023-01-26 17:13:57.821 No download requests in the queue to start downloads for. | 2023-01-26 17:13:57.821 No download requests in the queue to start downloads for. | 2023-01-26 17:13:57.821 No download requests in the queue to start downloads for. | 2023-01-26 17:13:57.821 Trading Evaluator | Requesting historical order activity from server. Start date-time UTC: 2023-01-26 15:04:50.317093 | 2023-01-26 17:13:57.838 Mapping 6BH23 to 6BH23. Service code: cme | 2023-01-26 17:13:58.012 Using symbol data fast lookup vector | 2023-01-26 17:13:58.012 SC Data - All Services | Starting real-time market data updates for: 6BH23 (6BH23). ID: 1 Service code: cme | 2023-01-26 17:13:58.012 SC Data - All Services | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-01-26 17:13:58.012 SC Data - All Services | Requesting security definition data for: 6BH23 (6BH23). ID: 1 | 2023-01-26 17:13:58.012 Added historical Intraday data request for 6BH23 to the queue. | 2023-01-26 17:13:58.012 Intraday data recording state for symbol 6BH23 is set to download 'Pending'. | 2023-01-26 17:13:58.012 Triggering next historical data download in queue. | 2023-01-26 17:13:58.012 DTC Client socket (4) | Creating socket. | 2023-01-26 17:13:58.013 DTC Client socket (4) | New receive buffer size: 5242880 | 2023-01-26 17:13:58.013 DTC Client socket (4) | Connecting to IP: 142.215.18.147. | 2023-01-26 17:13:58.013 Delaying start of download for 6BH23. | 2023-01-26 17:13:58.021 Trading Evaluator | Received final trade activity snapshot. Count=1. No data. TradeAccount=Test_Vince | 2023-01-26 17:13:58.021 Requesting market depth updates for: 6BH23 if supported. | 2023-01-26 17:13:58.101 Separate subscription for market depth updates not supported. 6BH23 | 2023-01-26 17:13:58.101 Mapping M6BH23 to M6BH23. Service code: cme | 2023-01-26 17:13:58.113 SC Data - All Services | Starting real-time market data updates for: M6BH23 (M6BH23). ID: 2 Service code: cme | 2023-01-26 17:13:58.113 SC Data - All Services | Requesting security definition data for: M6BH23 (M6BH23). ID: 2 | 2023-01-26 17:13:58.113 Added historical Intraday data request for M6BH23 to the queue. | 2023-01-26 17:13:58.113 Intraday data recording state for symbol M6BH23 is set to download 'Pending'. | 2023-01-26 17:13:58.113 Triggering next historical data download in queue. | 2023-01-26 17:13:58.113 SC Data - All Services | Network connection to server complete. | 2023-01-26 17:13:58.196 SC Data - All Services | Starting socket receive thread. | 2023-01-26 17:13:58.196 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2023-01-26 17:13:58.196 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BH23 | 2023-01-26 17:13:58.250 Trading Evaluator | Received security definition for symbol 6BH23 | 2023-01-26 17:13:58.250 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M6BH23 | 2023-01-26 17:13:58.322 Trading Evaluator | Received security definition for symbol M6BH23 | 2023-01-26 17:13:58.322 SC Data - All Services | Setting DTC encoding to Binary VLS | 2023-01-26 17:13:58.360 SC Data - All Services | Sending logon request message. | 2023-01-26 17:13:58.360 Mapping ZNM23 to ZNM23. Service code: cbot | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ZNM23 (ZNM23). ID: 3 Service code: cbot | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Requesting security definition data for: ZNM23 (ZNM23). ID: 3 | 2023-01-26 17:13:58.495 Mapping ZNH23 to ZNH23. Service code: cbot | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ZNH23 (ZNH23). ID: 4 Service code: cbot | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Requesting security definition data for: ZNH23 (ZNH23). ID: 4 | 2023-01-26 17:13:58.495 Mapping ESM23 to ESM23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: ESM23 (ESM23). ID: 5 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: ESM23 (ESM23). ID: 5 | 2023-01-26 17:13:58.495 Mapping ESH23 to ESH23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: ESH23 (ESH23). ID: 6 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: ESH23 (ESH23). ID: 6 | 2023-01-26 17:13:58.495 Mapping CLJ23 to CLJ23. Service code: nymex | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLJ23 (CLJ23). ID: 7 Service code: nymex | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Requesting security definition data for: CLJ23 (CLJ23). ID: 7 | 2023-01-26 17:13:58.495 Mapping CLK23 to CLK23. Service code: nymex | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLK23 (CLK23). ID: 8 Service code: nymex | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Requesting security definition data for: CLK23 (CLK23). ID: 8 | 2023-01-26 17:13:58.495 Mapping CLM23 to CLM23. Service code: nymex | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLM23 (CLM23). ID: 9 Service code: nymex | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Requesting security definition data for: CLM23 (CLM23). ID: 9 | 2023-01-26 17:13:58.495 Mapping 6BM23 to 6BM23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: 6BM23 (6BM23). ID: 10 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: 6BM23 (6BM23). ID: 10 | 2023-01-26 17:13:58.495 Mapping 6EM23 to 6EM23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: 6EM23 (6EM23). ID: 11 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: 6EM23 (6EM23). ID: 11 | 2023-01-26 17:13:58.495 Mapping 6EH23 to 6EH23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: 6EH23 (6EH23). ID: 12 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: 6EH23 (6EH23). ID: 12 | 2023-01-26 17:13:58.495 Mapping M6BM23 to M6BM23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: M6BM23 (M6BM23). ID: 13 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: M6BM23 (M6BM23). ID: 13 | 2023-01-26 17:13:58.495 Mapping M6BU23 to M6BU23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: M6BU23 (M6BU23). ID: 14 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: M6BU23 (M6BU23). ID: 14 | 2023-01-26 17:13:58.495 Mapping M2KH23 to M2KH23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: M2KH23 (M2KH23). ID: 15 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: M2KH23 (M2KH23). ID: 15 | 2023-01-26 17:13:58.495 Mapping RTYH23 to RTYH23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: RTYH23 (RTYH23). ID: 16 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: RTYH23 (RTYH23). ID: 16 | 2023-01-26 17:13:58.495 Mapping MNQH23 to MNQH23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: MNQH23 (MNQH23). ID: 17 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: MNQH23 (MNQH23). ID: 17 | 2023-01-26 17:13:58.495 Mapping NQH23 to NQH23. Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Starting real-time market data updates for: NQH23 (NQH23). ID: 18 Service code: cme | 2023-01-26 17:13:58.495 SC Data - All Services | Requesting security definition data for: NQH23 (NQH23). ID: 18 | 2023-01-26 17:13:58.495 DTC Client socket (5) | Creating socket. | 2023-01-26 17:13:58.495 DTC Client socket (5) | New receive buffer size: 5242880 | 2023-01-26 17:13:58.495 DTC Client socket (5) | Connecting to IP: 142.215.17.190. | 2023-01-26 17:13:58.495 SC DTC Delayed Exchange Data | Network connection to server complete. | 2023-01-26 17:13:58.655 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2023-01-26 17:13:58.655 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2023-01-26 17:13:58.655 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM23 | 2023-01-26 17:13:58.656 Trading Evaluator | Received security definition for symbol ESM23 | 2023-01-26 17:13:58.656 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH23 | 2023-01-26 17:13:58.656 Trading Evaluator | Received security definition for symbol ESH23 | 2023-01-26 17:13:58.656 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BM23 | 2023-01-26 17:13:58.656 Trading Evaluator | Received security definition for symbol 6BM23 | 2023-01-26 17:13:58.656 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EM23 | 2023-01-26 17:13:58.715 Trading Evaluator | Received security definition for symbol 6EM23 | 2023-01-26 17:13:58.715 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH23 | 2023-01-26 17:13:58.715 Trading Evaluator | Received security definition for symbol 6EH23 | 2023-01-26 17:13:58.715 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M6BM23 | 2023-01-26 17:13:58.715 Trading Evaluator | Received security definition for symbol M6BM23 | 2023-01-26 17:13:58.715 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M6BU23 | 2023-01-26 17:13:58.715 Trading Evaluator | Received security definition for symbol M6BU23 | 2023-01-26 17:13:58.715 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M2KH23 | 2023-01-26 17:13:58.715 Trading Evaluator | Received security definition for symbol M2KH23 | 2023-01-26 17:13:58.715 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH23 | 2023-01-26 17:13:58.715 Trading Evaluator | Received security definition for symbol RTYH23 | 2023-01-26 17:13:58.715 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQH23 | 2023-01-26 17:13:58.715 Trading Evaluator | Received security definition for symbol MNQH23 | 2023-01-26 17:13:58.715 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH23 | 2023-01-26 17:13:58.715 Trading Evaluator | Received security definition for symbol NQH23 | 2023-01-26 17:13:58.715 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2023-01-26 17:13:58.846 SC DTC Delayed Exchange Data | Sending logon request message. | 2023-01-26 17:13:58.846 SC Data - All Services | Received logon response. | 2023-01-26 17:13:59.301 SC Data - All Services | Server Name: SC Realtime Server. | 2023-01-26 17:13:59.301 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2023-01-26 17:13:59.301 SC Data - All Services | Successfully connected. | 2023-01-26 17:13:59.301 SC Data - All Services | Trading is not supported. | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: 6BH23 -> 6BH23. Market Depth data restarted. | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: 6BM23 -> 6BM23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: 6EH23 -> 6EH23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: 6EM23 -> 6EM23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: ESH23 -> ESH23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: ESM23 -> ESM23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: M2KH23 -> M2KH23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: M6BH23 -> M6BH23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: M6BM23 -> M6BM23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: M6BU23 -> M6BU23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: MNQH23 -> MNQH23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: NQH23 -> NQH23 | 2023-01-26 17:13:59.301 SC Data - All Services | Restarting real-time data updates for symbol: RTYH23 -> RTYH23 | 2023-01-26 17:13:59.301 SC DTC Delayed Exchange Data | Received logon response. | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Successfully connected. | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Trading is not supported. | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLJ23 -> CLJ23 | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLK23 -> CLK23 | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLM23 -> CLM23 | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ZNH23 -> ZNH23 | 2023-01-26 17:13:59.627 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ZNM23 -> ZNM23 | 2023-01-26 17:13:59.627 SC Data - All Services | Clearing market depth for 6BH23 | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol 6BH23 | 2023-01-26 17:13:59.696 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\6BH23.2023-01-26.depth | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol 6BM23 | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol 6EH23 | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol 6EM23 | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol ESH23 | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol ESM23 | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol M2KH23 | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol M6BH23 | 2023-01-26 17:13:59.696 SC Data - All Services | Received security definition for symbol M6BM23 | 2023-01-26 17:13:59.696 SC Data - All Services | Real-time data for symbol M6BU23 is currently unavailable. | 2023-01-26 17:13:59.697 SC Data - All Services | Received security definition for symbol M6BU23 | 2023-01-26 17:13:59.697 SC Data - All Services | Received security definition for symbol MNQH23 | 2023-01-26 17:13:59.697 SC Data - All Services | Received security definition for symbol NQH23 | 2023-01-26 17:13:59.697 SC Data - All Services | Received security definition for symbol RTYH23 | 2023-01-26 17:13:59.697 SC DTC Delayed Exchange Data | Received security definition for symbol CLJ23 | 2023-01-26 17:13:59.878 SC DTC Delayed Exchange Data | Received security definition for symbol CLK23 | 2023-01-26 17:13:59.878 SC DTC Delayed Exchange Data | Received security definition for symbol CLM23 | 2023-01-26 17:13:59.878 SC DTC Delayed Exchange Data | Received security definition for symbol ZNH23 | 2023-01-26 17:13:59.878 SC DTC Delayed Exchange Data | Received security definition for symbol ZNM23 | 2023-01-26 17:13:59.878 Requesting market depth updates for: M6BH23 if supported. | 2023-01-26 17:14:02.807 SC Data - All Services | Clearing market depth for M6BH23 | 2023-01-26 17:14:02.976 HD Request # 10 | Downloading Intraday chart data for 6BH23 to the file 6BH23.scid. Service: cme | 2023-01-26 17:14:04.764 HD Request # 10 | Download start date-time: 2023-01-26 17:13:44.000000. File last date-time: 2023-01-26 17:13:44.390000 | 2023-01-26 17:14:04.764 HD Request # 10 | Using server: ds26.sierracharts.com port 10150 | 2023-01-26 17:14:04.764 Socket (6) | Creating socket. | 2023-01-26 17:14:04.764 Socket (6) | New receive buffer size: 5242880 | 2023-01-26 17:14:04.764 Socket (6) | Connecting to IP: 142.215.17.188. | 2023-01-26 17:14:04.764 HD Request # 10 | Setting DTC encoding to Binary VLS | 2023-01-26 17:14:05.077 HD Request # 10 | Sending historical data logon request message. | 2023-01-26 17:14:05.077 HD Request # 10 | Requesting Intraday data. Start date-time: 2023-01-26 17:13:44. Record interval: 0. Symbol: 6BH23 | 2023-01-26 17:14:05.779 HD Request # 10 | Decompressing data. | 2023-01-26 17:14:05.930 HD Request # 10 | Receiving Intraday data for 6BH23 starting at 2023-01-26 17:13:44.390000 | 2023-01-26 17:14:05.930 Socket (6) | CloseSocket call. | 2023-01-26 17:14:05.930 Socket (6) | Shutdown started. Waiting for graceful close. | 2023-01-26 17:14:05.930 Historical data download thread signaled to stop. | 2023-01-26 17:14:05.930 HD Request # 10 | Timestamp of first Intraday data file record written: 2023-01-26 17:13:49.109000. | 2023-01-26 17:14:05.930 HD Request # 10 | Received 15 Intraday data records from 2023-01-26 17:13:44.390000 to 2023-01-26 17:14:01.025000 (16.6 seconds) and wrote 14 records for 6BH23 | 2023-01-26 17:14:05.930 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2023-01-26 15:14:01.025000 | 2023-01-26 17:14:05.934 Added 3 Time and Sales records to Intraday data file for 6BH23 after download. | 2023-01-26 17:14:05.934 HD Request # 10 | Completion time: 1s. | 2023-01-26 17:14:05.934 HD Request # 10 | Intraday data download complete for 6BH23. Unique request ID: 10 | 2023-01-26 17:14:05.934 Removing historical data download ID 10. | 2023-01-26 17:14:05.934 Real-time Intraday chart data file updates started for 6BH23 | 2023-01-26 17:14:05.934 Intraday chart data file opened for 6BH23 | 2023-01-26 17:14:05.934 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2023-01-26 17:14:05.934 Triggering next historical data download in queue. | 2023-01-26 17:14:05.934 HD Request # 11 | Downloading Intraday chart data for M6BH23 to the file M6BH23.scid. Service: cme | 2023-01-26 17:14:05.934 HD Request # 11 | Download start date-time: 2023-01-26 17:13:44.000000. File last date-time: 2023-01-26 17:13:44.390001 | 2023-01-26 17:14:05.935 HD Request # 11 | Using server: ds28.sierracharts.com port 10149 | 2023-01-26 17:14:05.935 Socket (7) | Creating socket. | 2023-01-26 17:14:05.935 Socket (7) | New receive buffer size: 5242880 | 2023-01-26 17:14:05.935 Socket (7) | Connecting to IP: 142.215.18.147. | 2023-01-26 17:14:05.935 Socket (6) | Socket gracefully closed by remote side. | 2023-01-26 17:14:06.082 Socket (6) | Closed. | 2023-01-26 17:14:06.082 : Array is unallocated. | 2023-01-26 17:14:06.193 : Array is unallocated. | 2023-01-26 17:14:06.193 Chart #3 has tagged chart #17 for full recalculation. Chartbook: GBPUSD 2 .Cht | 2023-01-26 17:14:06.193 HD Request # 11 | Setting DTC encoding to Binary VLS | 2023-01-26 17:14:06.249 HD Request # 11 | Sending historical data logon request message. | 2023-01-26 17:14:06.249 M6BH23[M] Renko 3t #17 | Performing a full recalculation because it has been tagged. Chartbook: GBPUSD 2 .Cht | 2023-01-26 17:14:06.624 : Array is unallocated. | 2023-01-26 17:14:06.697 : Array is unallocated. | 2023-01-26 17:14:06.697 HD Request # 11 | Requesting Intraday data. Start date-time: 2023-01-26 17:13:44. Record interval: 0. Symbol: M6BH23 | 2023-01-26 17:14:06.935 HD Request # 11 | Decompressing data. | 2023-01-26 17:14:07.103 HD Request # 11 | Receiving Intraday data for M6BH23 starting at 2023-01-26 17:13:44.390000 | 2023-01-26 17:14:07.104 Socket (7) | CloseSocket call. | 2023-01-26 17:14:07.104 Historical data download thread signaled to stop. | 2023-01-26 17:14:07.104 Socket (7) | Shutdown started. Waiting for graceful close. | 2023-01-26 17:14:07.104 HD Request # 11 | Received 2 Intraday data records from 2023-01-26 17:13:44.390000 to 2023-01-26 17:13:44.390001 (0.0 seconds) and wrote 0 records for M6BH23 | 2023-01-26 17:14:07.104 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2023-01-26 15:13:44.390001 | 2023-01-26 17:14:07.104 HD Request # 11 | Completion time: 2s. | 2023-01-26 17:14:07.104 HD Request # 11 | Intraday data download complete for M6BH23. Unique request ID: 11 | 2023-01-26 17:14:07.104 Removing historical data download ID 11. | 2023-01-26 17:14:07.104 Real-time Intraday chart data file updates started for M6BH23 | 2023-01-26 17:14:07.104 Intraday chart data file opened for M6BH23 | 2023-01-26 17:14:07.104 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2023-01-26 17:14:07.104 Triggering next historical data download in queue. | 2023-01-26 17:14:07.104 No download requests in the queue to start downloads for. | 2023-01-26 17:14:07.104 Chart #17 has tagged chart #3 for full recalculation. Chartbook: GBPUSD 2 .Cht | 2023-01-26 17:14:07.183 6BH23/M6BH23[M] Renko 3t #3 | Performing a full recalculation because it has been tagged. Chartbook: GBPUSD 2 .Cht | 2023-01-26 17:14:07.242 Socket (7) | Socket gracefully closed by remote side. | 2023-01-26 17:14:07.257 Socket (7) | Closed. | 2023-01-26 17:14:07.257 : Array is unallocated. | 2023-01-26 17:14:07.289 : Array is unallocated. | 2023-01-26 17:14:07.289 : Array is unallocated. | 2023-01-26 17:14:07.717 : Array is unallocated. | 2023-01-26 17:14:07.717 Opened cached Intraday file: C:\SierraChart\Data\6BH23.scid. Thread ID: 14628 | 2023-01-26 17:14:11.567 Opened cached Intraday file: C:\SierraChart\Data\M6BH23.scid. Thread ID: 14628 | 2023-01-26 17:14:11.568 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Creating socket. Using TLS 1.2. | 2023-01-26 17:15:11.756 The message log has been sent to support. | 2023-01-26 17:15:11.756 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | New receive buffer size: 32768 | 2023-01-26 17:15:11.756 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Connecting to IP: 95.216.233.104. | 2023-01-26 17:15:11.756 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2023-01-26 17:15:12.326 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | CloseSocket call. | 2023-01-26 17:15:12.592 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Shutdown started. Waiting for graceful close. | 2023-01-26 17:15:12.592 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Socket gracefully closed by remote side. | 2023-01-26 17:15:12.729 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Closed. | 2023-01-26 17:15:12.730 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-01-26 17:16:10.996 DTC Client socket (1) | Closed. | 2023-01-26 17:16:10.996 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-01-26 17:16:10.996 DTC Client socket (2) | Closed. | 2023-01-26 17:16:10.996 DTC Client socket (1) | Deleting network socket now after delay. | 2023-01-26 17:16:41.002 DTC Client socket (2) | Deleting network socket now after delay. | 2023-01-26 17:16:41.002 Saved Chartbook: GBPUSD 2 .Cht. Time: 0.0197 seconds. | 2023-01-26 17:17:59.611 |
[2023-01-26 23:35:55] |
We need to know specifically what symbol you are having a problem with. This is critical.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-26 23:36:23
[2023-01-27 12:39:35] |
Dear Reader, The symbols are 6BH23/M6BH23 Regards, |
[2023-01-27 16:21:37] |
Open a separate chart for one of those symbols. And do not use the Trade and Current Quote Symbol setting. Keep that blank. See if you still notice the problem.
