Date/Time: Tue, 22 Apr 2025 02:21:38 +0000
Binance connection down?
View Count: 851
[2023-01-23 19:08:08]
T44 - Posts: 363
SC DTC Data with Market Depth | Real-time data for symbol LTCUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol LINKUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol FTMUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol BCHUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol FTTUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol YFIBUSD-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol SRMUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol UNIBUSD-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol AAVEBUSD-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol FTTBUSD-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol GMTUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol APEUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol APEBUSD-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol LDOUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol OPUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol LUNCUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
SC DTC Data with Market Depth | Real-time data for symbol APTUSDT-BINANCE is currently unavailable. | 2023-01-23 19:06:57.085
Switched on Sierra today, no changes my size, extra 2 decimals added to ETHUSDT-BINANCE chart scale, no live data, and messages like above in the logs
Date Time Of Last Edit: 2023-01-23 19:08:58
[2023-01-23 19:09:24]
T44 - Posts: 363
Updating to latest version didn't fix.
[2023-01-23 19:37:01]
T44 - Posts: 363
Fixed now, some intraday data from today missing, not cured by redownload so maybe didn't arrive at Sierra.
[2023-01-23 22:18:36]
Sierra_Chart Engineering - Posts: 19290
There were numerous small interruptions with the Binance data feed in the 1800 UTC hour today 2023-01-23. Causing missing data intermittently during that time.
Date Time Of Last Edit: 2023-01-23 22:18:47
[2023-01-24 13:51:26]
User738007 - Posts: 11
Binance data is not available at the moment. Apparently the service can not cope with the increased flow of transactions.
[2023-01-24 14:57:23]
For what symbol? We are seeing real-time updating data from Binance now.
Date Time Of Last Edit: 2023-01-24 14:57:33
[2023-01-24 15:18:27]
Yes, it's all right now. The problems were for about 10-15 minutes during the 'strong' price movement, just like yesterday. Symbols - the first three futures with the largest volumes.
[2023-01-29 10:57:07]
btcusdt-binance is not working at the moment
[2023-01-29 16:30:25]
bnbusdt_perp_binance is not working at the moment
[2023-01-29 22:58:26]
Ok, are you still noticing a problem with that symbol? You should not be.
[2023-01-30 11:55:21]
At the moment everything is fine. If there are any problems, I will let you know if the opportunity arises.
[2023-02-04 18:41:27]
Sometimes there is a loss of data for 30-50 seconds.
[2023-02-05 14:28:50]
[2023-02-22 08:14:55]
btcusdtperp-binance is not working at the moment
Date Time Of Last Edit: 2023-02-22 09:05:46
[2023-02-23 15:25:49]
Binance is out of service again
[2023-02-23 16:31:27]
John - SC Support - Posts: 39395
User738007:
You are posting from an expired account. If you use a different account, then you need to post from that one.
With regards to Binance, there is little we can do. They are having issues sending us the data.
[2023-02-23 16:46:15]
For the Multicharts platform, the binance data source works without interruption, but it is not as convenient as Sierrachart.
