Date/Time: Fri, 18 Jul 2025 23:48:37 +0000
US Stocks and MBO
View Count: 512
[2023-01-22 19:28:09] |
OYK21_gp - Posts: 1 |
Hello - Currently have Denali for futures. Is it possible to also get realtime data with MBO for US based stocks? And would tenton order routing work for stocks too? Or is it just an engine for futures tied to futures exchanges? Thank you. |
[2023-01-23 04:33:44] |
Sierra_Chart Engineering - Posts: 20254 |
Yes you can get market by order data, with the NASDAQ TotalView data feed which is part of the Denali Data Feed: Denali Exchange Data Feed Teton order routing is just for CME Group exchanges only. Not stocks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
