Date/Time: Fri, 18 Apr 2025 19:00:43 +0000
Connecting broker
View Count: 396
[2023-01-22 14:44:58]
User604473 - Posts: 4
I have already a funded trading account with Tradovate, and another one with Tradestation.
Is there any way I can connect one on these to sierra chart to trade directly from SC, using them as a broker and Denali as data feed ?
If not, what is the best option between AMP and Edge Clear ?
Thank you .
[2023-01-23 04:28:20]
Sierra_Chart Engineering - Posts: 19269
No you cannot use either of those first two mentioned brokers.
We would definitely recommend using a broker supporting Teton and Edge Clear does. Refer to:
