Date/Time: Tue, 22 Apr 2025 18:33:46 +0000
Quote Board
View Count: 591
[2023-01-22 14:22:32] |
58LesPaul - Posts: 429 |
Is there a way to hide the title bar on the Quote Board? If not, can this be implemented? When using multiple charts along with a quote board the extra space by hiding the quote board title bar comes in handy. Thanks Date Time Of Last Edit: 2023-01-22 14:26:26
[2023-01-23 18:31:34] |
John - SC Support - Posts: 39418 |
There is not a way to remove the Title Bar from the Quote Board. This is not something we will change for the current implementation. We'll have to see how doable it would be with our new windows.
[2023-01-23 20:56:48] |
User90125 - Posts: 715 |
Would it be possible to add Quote Board fields that show the Current Margin and Maintenance Margin for Teton users? Thanks. |
[2023-01-31 23:33:58] |
+1 for follow-up
[2023-02-06 16:35:33] |
Sierra_Chart Engineering - Posts: 19305 |
No, this is not supported. It could not be. These are not market data fields. They are account specific. However, you can find this information through this tab: Trade Account and Risk Management: Viewing Margin Requirement for Symbol and Trade Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-06 17:24:19] |
The Quote Board already supports several account specific fields, namely Position (Non-Sim) OpenBuyQty (Non-Sim) OpenSellQty (Non-Sim) OpenPositionP/L DailyP/L Thus, adding fields for the Current Margin and Maintenance Margin shouldn't be insurmountable (costs & time notwithstanding). |
[2023-03-17 22:12:25] |
+1 for follow up.
