Date/Time: Fri, 18 Apr 2025 19:01:52 +0000
Sierra Chart Trading
View Count: 483
[2023-01-20 18:42:07]
User621901 - Posts: 3
What i am trying to do is essentially i wanna to submit Single Stock orders from sierra chart, using sierra data and using its charting tools.
So i wanna to connect my platform API to sierra, can i do this by making DTC ??
i am trading with DTTW and they using platform called PPRO8
The PPro8 API is a web service which, when enabled, allows the user to pass commands using URL format.
Link: https://www.ppro8wiki.com/doku.php?id=pproapi
is there any template or similarity with any the platforms which sierra support trading with so i can adjust it to work the PPRO8 API, or any advice to start with???
Date Time Of Last Edit: 2023-01-23 13:54:47
