Date/Time: Fri, 18 Apr 2025 18:58:44 +0000
Draws and calculations per second adjustment
View Count: 498
[2023-01-20 15:50:02] |
DDC - Posts: 31 |
Hi all. For all of my charts, my draws and calcs per second are 1. It doesn't change when I adjust my chart update interval to <1000 milliseconds. Is that a function of my data feed only providing data once per second or is there a way to adjust that so I'm seeing data and calculations on my charts more frequently? Thank you in advance |
[2023-01-21 00:07:42] |
Sierra_Chart Engineering - Posts: 19269 |
There were problems with the calculation/display of this information in older versions. You need to update to resolve this.: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-21 00:07:57
[2023-01-21 14:25:58] |
DDC - Posts: 31 |
Ok, so if I download the newer version and adjust the chart update time in milliseconds, I’ll get the data populated onto the chart faster? So, 500 milliseconds will give me updates 2x per second? Is that correct?
[2023-01-21 17:22:59] |
Yes.
