Date/Time: Fri, 18 Apr 2025 19:01:52 +0000
Downloading market depth data longer than 60 days
View Count: 1520
[2023-01-20 00:34:19] |
User239246 - Posts: 3 |
Hello, I am only able to download up to 60 days of market depth data for the ES. I believe CME has up to 180 days of market depth data. Is there a way that I can download through Sierra charts more than 60 days of market depth data? Right clicking and downloading depth from date time only works for up to 60 days. Or can I also download older data from CME and import it to Sierra charts? Thank you.
[2023-01-20 05:09:24] |
Sierra_Chart Engineering - Posts: 19269 |
There is 180 days of data available. However, you probably would need to use the March 2023 symbol and the December 2022 symbol and the September 2022 symbol to get all of the data. So you need to open charts for these separately. Go through all of the steps here: Market Depth Historical Graph: Downloading Of Historical Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-20 05:10:58
[2023-01-21 01:51:01] |
Thank you so much, I had it set to 60 days.
