Date/Time: Fri, 18 Apr 2025 16:33:06 +0000
Chart Trade Windows not synced
View Count: 318
[2023-01-19 15:42:34]
__Kai__ - Posts: 15
I have two ES charts open with a chart trader attached to both. But for some reason the P/L fileds of the second chart trader is empty (see screenshot). The trades are visibel in both charts and the number of trades as well. Both charts are linked.
I checked all chart trader related settings but there is no difference. Please adivice.
Thank you.
image2023-01-19 16_37_58-#3 ES-202303-CME.png / V - Attached On 2023-01-19 15:39:09 UTC - Size: 255.15 KB - 94 views
[2023-01-19 17:09:28]
John - SC Support - Posts: 39356
It looks like the chart that is not showing any Profit/Loss information has the Setting for Chart >> Chart Settings >> Trading >> Profit/Loss Format set to Do Not Display. If you change this to match the other chart (Currency Value and Points) then you should get the same information. Refer to the documentation here:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
Date Time Of Last Edit: 2023-01-19 17:10:10
