Date/Time: Fri, 18 Apr 2025 16:29:38 +0000
Quote Board / OpenPositionP/L
View Count: 439
[2023-01-19 08:57:12]
User871209 - Posts: 91
On my Quote Board, I have set it to show the field of OpenPositionP/L it only will show my PL if I am on the selected symbol, when I change to another instrument the PL disappears.
Is there a way to always have it visible in the different positions I have to show the PL without disappearing?
Thank you,
Regards,
[2023-01-19 15:05:00]
Sierra_Chart Engineering - Posts: 19269
What exactly does this mean?:
Where are you referring to?
Where are you changing the symbol?
Date Time Of Last Edit: 2023-01-19 15:12:12
[2023-01-19 16:01:16]
When I press on the quote board for example on Micro Emini Symbol it will show me the PL of the chart open position, but I change to another symbol the PL disappears.
Attached is my quote board in which I have open 3 positions but it only shows me the PL for one.
Please let me know,
Thanks,
The attached quote board not showing the PL for the other 2 positions that are open.
imagedd.JPG / V - Attached On 2023-01-19 15:59:39 UTC - Size: 117.44 KB - 93 views
[2023-01-19 17:59:21]
John - SC Support - Posts: 39356
Make sure the Chart >> Chart Settings >> Trade >> Profit/Loss Format for the charts that are not showing any P/L is set to a value other than Do Not Display. Refer to the following documentation:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
Date Time Of Last Edit: 2023-01-19 17:59:49
