Date/Time: Tue, 26 Nov 2024 17:38:58 +0000
SierraChart Will not open, Help.
View Count: 1140
[2014-06-04 20:15:12]
GCAdmin - Posts: 35
I downloaded SierraChart to my PC. It downloaded perfectly, but now that it is downloaded I go to open it and it will not open at all. Nothing comes up when I double click on the shortcut or even when I select it from the programs list to open. What could be causing this issue?
Thanks!
[2014-06-04 21:43:54]
For a problem like this we recommend using the non-CLR version. It can be downloaded with this link:
https://www.sierrachart.com/downloads/SierraChartSetupNoCLR.exe
