Date/Time: Fri, 18 Apr 2025 16:29:39 +0000
Exception when calling sc.GetFlatToFlatTradeListEntry
View Count: 383
[2023-01-18 20:45:05] |
User907968 - Posts: 840 |
I am getting access violation exceptions when calling sc.GetFlatToFlatTradeListEntry in pre-release version 2472. Assume this relates to the recent changes in s_ACSTrade? So far I have observed this in studies built on version 2347. If possible please confirm as I have many studies built on older versions that will be affected by this problem. Thanks Edit: should've said v2472, i.e. the latest pre-release Date Time Of Last Edit: 2023-01-19 09:43:25
[2023-01-19 03:11:49] |
Sierra_Chart Engineering - Posts: 19269 |
We will check this.
[2023-01-19 03:43:17] |
We looked into this closely, you should not be encountering an exception. Although, there was a new structure member added for that data structure s_ACSTrade. However, it is only set if the data structure based upon the version of the DLL has that member. So there is no chance of any exception. At this point our recommendation is just to recompile the custom study for the version that you are using it on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-19 03:43:41
