Date/Time: Tue, 26 Nov 2024 17:24:08 +0000
Continuous contracts and CTS- missing for some symbols
View Count: 1501
[2014-06-04 20:14:59] |
Joe Hobart - Posts: 89 |
Having problems with contract joining using CTS. seems like problems with volume and date based. I have not tried to do yearly, quarterly or monthly charts since the CTS symbol shakeup, so i don't know if this ever worked. Running 1143. YM, NQ, TF, and SB (ICE sugar) YMM14/YM.20140600.CME_E [CBV] Yearly #5: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-06-04 15:58:22 NQM14/NQ.20140600.CME_Eq [CBV] Yearly #5: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-06-04 16:04:25\\ Tf and sugar (both ICE) seems to throw all kinds of crazy errors. SB.20140700.ICE_CO [CBV] Quarterly #6: SB.20130700.ICE_CO price difference to SB.20131000.ICE_CO is 0. | 2014-06-04 16:11:57 Error while getting daily open price with date 2013-09-30 from file. C:\SierraChart2\Data\SB.20131000.ICE_CO.dly. Error: Encountered end of file. | 2014-06-04 16:11:57 |
[2014-06-04 22:39:59] |
You need to update the symbol settings by following the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings After that you need to go to each chart that is giving this message: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart.
And select Chart >> Reload and Recalculate. For this symbol: SB.20140700.ICE_CO Open a new chart through File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-05 00:04:04] |
Thank you, this resolved the problem. The Historical Chart Symbol was blank on the broken symbols. update from server fixed it.
