Date/Time: Fri, 18 Apr 2025 16:31:51 +0000
Saving all charts and settings
View Count: 813
[2023-01-18 20:02:01] |
User924806 - Posts: 20 |
Hi, I have to reinstall windows OS on my computer and I'd like to know if there is a way to save all my Sierra Charts settings and charts onto an external drive so I can recover them after I reinstall Windows OS and I don't have to rebuild them again? Thanks, Claudius |
[2023-01-18 22:21:16] |
John - SC Support - Posts: 39356 |
The information on the files you will want is at step #5 of the following link: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
