Date/Time: Fri, 18 Apr 2025 16:42:27 +0000
How to add volume profile to side of chart
View Count: 518
[2023-01-18 19:38:55]
User994719 - Posts: 21
Hi i would love some help with how to get the profile on the side of a chart. Thank you in advance
example picture attached.
Date Time Of Last Edit: 2023-01-18 19:39:27
imageMedia viewer 18_01_2023 19_33_31.png / V - Attached On 2023-01-18 19:38:33 UTC - Size: 230.77 KB - 134 views
[2023-01-18 22:20:16]
John - SC Support - Posts: 39356
In order to do that you need to setup the Profile as you want it and then set the Volume by Price Input for Always Display Last Profile Within View. Refer to the following:
Volume By Price Study: Always Display Last Profile Within View
You will probably also want to change the Maximum Volume Bar Width Type and Maximum Volume Bar Width Percentage. Refer to the information here:
Volume By Price Study: Maximum Volume Bar Width Type
