Date/Time: Tue, 26 Nov 2024 17:42:06 +0000
fill offset using rithmic
View Count: 1161
[2014-06-04 19:37:56] |
umair1 - Posts: 86 |
I have been trading TF (Russell 2000 Index futures) over the past few weeks. I am using SC v1130 with Rithmic data feed. The rithmic symbol is TF FMM0014!-NYBOT I have noticed that if for example I sell TF at 1130, the fill price shows as 1130 (the indicator from "show order fills"), but the position shows as me having sold at 1130.5 ie 0.5 points higher than my fill price. See attached image Can you fix this? I have seen this happen several times and verified that for some reason I didn't actually get filled 0.5 points higher. Date Time Of Last Edit: 2014-06-04 19:40:23
fill_offset2.png / V - Attached On 2014-06-04 19:40:19 UTC - Size: 34.28 KB - 341 views |
[2014-06-05 07:12:57] |
Update Sierra Chart with Help >> Download Prerelease and let us know if you still see this problem. If you continue see the issue we need to understand the problem better. When you notice the problem go to Trade >> Trade Orders and Positions >> Positions. Does the Position Average Price you see on the Position line on the chart match the price you see for Trade Service Average Price on the Positions tab? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-05 07:15:14
