Date/Time: Fri, 18 Apr 2025 16:33:06 +0000
is it possible to trade one system through multiple spreadsheet for trading
View Count: 369
[2023-01-18 11:46:22]
User368741 - Posts: 57
I wanted to run multiple system on single symbol than will attached orders and exit will be a problem if the orders are generated in the same direction at the same time
[2023-01-18 15:25:00]
John - SC Support - Posts: 39356
You can not do this with a single symbol with a single trading account.
If you have multiple trading accounts, then you would need to have separate Sierra Chart installations (one for each account) and then you can trade each of them separately with their own spreadsheet systems.
