Date/Time: Fri, 18 Apr 2025 16:42:27 +0000
difeerences between SC data and CQGweb when subscribing to Denali
View Count: 400
[2023-01-18 05:25:05] |
User61576 - Posts: 445 |
hi can you please advise why when connected to CQGweb there is already a rollover for CL futures while the lower SC data service is connected to SC data all and there is no rollover? both are connected to Denali as I pay twice for the live connection thanks! |
![]() Attachment Deleted. |
[2023-01-18 23:35:26] |
Sierra_Chart Engineering - Posts: 19269 |
That rollover notice is not going to be on the chart at all times. And it is also affected by this setting: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
