Date/Time: Fri, 18 Apr 2025 16:35:18 +0000
Forward Curve Study Doesn't work for some symbols?
View Count: 449
[2023-01-17 17:51:35]
User409050 - Posts: 22
Hi SC Support team. I want to draw Forward curve for Fed Fund Futures and Crude Oil and VX
but only FC for VX works, the other 2 are just blank charts even though the inputs are all the same.
Thank you
[2023-01-17 18:55:25]
John - SC Support - Posts: 39356
The concept of a Forward Curve is for products that have a limited life and therefore have multiple contracts associated with them (hence - futures). That way, you are viewing the different contracts value in the future.
If you are looking at the CFDs for the Fed and Oil, then those will not work as they are not futures. If you are looking at futures for those products, then please let us know what symbol you are using.
[2023-01-17 19:08:56]
Hi John, thank for your reply, yes, i know what FC is and I do use futures symbols (CL and VXG23 for VIX (worked) and ZQF23 for Fed Fund Rates), but only FC for VIX works, i noticed that because the VX symbol has "real time" data.
the symbols that I use for Crude oil and FFR are CLG23 and ZQF23 both are most active contracts. is it because i use delayed data for those symbols? do I need to subscribe to Full CME data package in order for FC to work?
Thank you
[2023-01-17 21:39:28]
We do not think it is related to the Delayed Data, as it uses the Daily data for the future contracts for the date prior to today that you are looking for. So it should not matter. Also, you are not setup to get real-time data for the VIX futures, so that should be delayed data as well.
The one thing we want to ensure is that you are using the "Forward Curve" study and not just setting the Continuous Futures Contract Type to Forward Curve Study Support. You need to use the Forward Curve study.
But, the Forward Curve seems to be a bit touchy, as we had times when it would not show up with either real-time or delayed data.
What we recommend is to ensure you have the chart set back to a "normal" state, so ensure there is no Continuous Contract selected and make sure the Load Data Limiting Method is set to Use Number of Days to Load and that the Forward Curve is not on the chart.
Then when you add the Forward Curve, be sure to set the first Days Back for Forward Curve 1 to a value greater than 1. And the same for any other curves you want - be sure to set the number of days back to be greater than 1.
Then see if you are able to get the lines to show up properly for each of the symbols you want.
