Date/Time: Tue, 22 Apr 2025 07:57:13 +0000
Add watermark (or similar)
View Count: 984
[2023-01-17 17:37:05] |
OriolCasas - Posts: 189 |
Hello, I now have a lot of charts on my screens. CL, ES, tick, add, footprint. I would like to have a kind of water mark or somwthing where I could have the name of the product on. Is it possible to do this? Thank you |
[2023-01-17 18:49:58] |
Refer to the following: Symbol Display For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-03 16:21:12] |
joshtrader - Posts: 506 |
Unfortunately the text when using this study is clickable, so, clicking and dragging in the chart means I'm likely to click the symbol text and select it instead.
[2023-03-03 17:17:33] |
Once the study has put the drawing on the screen, you can right click and select "Lock Drawing". This will prevent your being able to move it.
