Date/Time: Fri, 18 Apr 2025 16:39:58 +0000
Default Alert Setting for Drawing Type
View Count: 489
[2023-01-17 16:21:43] |
User177741 - Posts: 48 |
Hi, Is there a way to setup a default for the alerts of a particular drawing type? For example, I use the Ray tool to draw trendlines... and I set alerts on them... now every time I draw a new line I need to go set the alert all over again! Is there a way to default enable alerts with the various settings for a given drawing type? If not this would indeed be a great feature. Thanks Kim |
[2023-01-17 16:51:45] |
John - SC Support - Posts: 39356 |
When you save a tool configuration the Alert settings are saved with it. Refer to the information at the following link for how to save configurations: Chart Drawing Tools: Drawing Tool Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-18 02:14:29] |
Perfect!!! This is one of the many reasons I LOVE Sierra!!!! Great software! And excellent responsive support team!
